How many regs | on ElectriciansForums
Discuss How many regs in the Electrical Course Trainees Only area at ElectriciansForums.net
Marvo
Mentor
South Africa
Okay I have a question for the trainees.
A friend of mine installed himself and extra socket last weekend. He dismantled an existing socket and drilled through the rear of the backbox into the adjacent room and surface mounted a new socket over the drilled hole and connected with a CAT5 cable. The only materials he used for the job was 1x steel backbox, 1xdouble switched socket and 400mm of CAT5e cable. Because of a difference in floor height between the two rooms the plugs wouldn't go into the socket because the cable in the plug was squashing tight against the floor. To work around this he mounted the new socket upside down so the plugs would go in easier.
How many regulations has he broken?
If you were filling out an EICR what codes would you give for the regulation infringements?
And before you ask I have no idea what the answer is so you'll have to fight it out amongst yourselves;)
Thanks Paul, I replied to your PM. I didn't think this would be such a scary question to be honest....or are the trainees just being a bunch of girls blouses...
Lol, yeah, we take recycling to a whole new level that's for sure.
CAT5 is data cable, stranded and very thin, probably about 0.5mm2? not fit for purpose that's for sure! haha "I think I smell something burning!!"
Yep the CAT 5 cable wouldn't have an appropriate CSA for a radial circuit supplying a socket. What code would you think for this on the EICR?
Also, I haven't worked it out via the adiabatic equation, but surely the CPC would be insufficiently sized too! will look up reg numbers later to try and apply them to this...
I'm not sure of the correct code to be honest, I've never done an EICR either. The volt drop across the cable would be high depending on the size of the load because the CSA of the wires is way too small. Finally you're correct again that the CPC is inadequate. I wouldn't bother with formulas in a case like this where the cable is being used in the wrong application, the fact it's a data cable would make it unsafe beyond doubt regardless of what the numbers say.
I'm very interested to see if anyone can find a breach in the UK regs with the socket mounted upside down at floor level. This alone would fail on account of at least 2 separate regs where I am.
Reply to How many regs in the Electrical Course Trainees Only area at ElectriciansForums.net
