This is all dependent on the space available in the CU and the number of circuits.
For those doing the decorative installations there is a large loop of cable behind the busbar possibly up to 150mm for the lines, the earths tend to be looped to the space behind the earth bar with about an 50-75mm leeway, neutral similar but often also looped down as well toward the MCBS.
There is one place I work on where the cables have been taken in all the way down the board, stripped from that point taken back up the board and then down to their connections, it is almost impossible to get to anything, identify any circuit wiring and the lid is difficult to get on, this is overdoing it!
I would generally aim to ensure that most new cables could reach any point in their relevant busbar so anywhere along the earth bar, any neutral bar or any MCB.
If there is enough room then I would try and have at least 50mm preferably 75mm flexibility.
