how much roughly? | on ElectriciansForums
Discuss how much roughly? in the UK Electrical Forum area at ElectriciansForums.net
T
tipex
hi all, how much is it roughly for a electric cert to say i can rent my house?
already got a gas cert, just need a electric one.
thanks in advance
I charge ÂŁ50 for initial testing and paperwork including 2 circuits. Then ÂŁ25 per circuit thereafter. So a house with 7 circuits (2 sockets,2 lights, 1 cooker, 1 shower, 1 Immersion) ÂŁ50 plus 5x ÂŁ25 = ÂŁ225 inc VAT
As it averages 45mins per circuit test it's a long winded job to do properly.
Don't trust very cheap quotes as they WILL be cutting corners on the inspecting side.
Don't assume it's going to pass though.
Tipex please be aware that the cost of testing that others have quoted does not mean you will be provided with a satisfactory cert and may come back with many items that need correcting as your question in the OP was so you can rent the property.
I'm sure and hope for you that no items need correcting but it may be that the place needs rewiring with can run into thousands so not an easy answer on that until you receive the results.
hope it doesn't need rewiring , it was done 11 years ago.
I carry out EICR's for ÂŁ70 for a one bedroom property with ÂŁ10 for each bedroom after that
This covers one DB / Consumer unit
I use easycert and do the software onsite
3 Bedroom house EICR ÂŁ100!!!!!! Really? I take it you're not VAT registered and the local price of a pint is ÂŁ1
- - - Updated - - -
I can't do maths obviously...... ÂŁ90!!!!!!
Reply to how much roughly? in the UK Electrical Forum area at ElectriciansForums.net
Yep They try to sell, sell, sell At the last asessment I told the asessor that I used SELECT to update my regs and inspection and testing, on...
Just have a look for plug in power monitors. Much quicker and cheaper probably
