C
CJE
Never priced a job before. Work in a warehouse unit involves: running a 4mm 3 core swa supplying 5 double sockets on a 32A radial ( 40m run): running a 16mm 4 core swa submain cable supplying additional 3 phase distribution board (40m run): supplying a 3 phase power outlet, single phase power outlet, rotary isolator for a compressor all from new distribution board.
Should take 2 8 hour days with two men.
All swa cables are to be cleated by use of plug and screw.
Any advice would be much appreciated.
