How much would you charge? | on ElectriciansForums
Discuss How much would you charge? in the UK Electrical Forum area at ElectriciansForums.net
F
Flakey
Hi there guys,
Ive been an electrician for a number of years working for a weekly wage but seem to be getting a number of private jobs coming in lately.
I just wanted a rough idea as to what you would charge for the following so as not to over charge and also not shoot myself in the foot.
1)Under kitchen cupboard LED lights power is already in 2 areas under the cupboard and are already wired to switch. So fairly easy
2)Adding 2 additional lights (baton holders) to existing circuit in attic. so basically come off existing light to make roof void more brighter.
3)Adding garden socket including running the cabling about 7 metres includes drilling through inside wall just behind existing socket then running the cable 7 metres to location, connect IP rated socket.
4)replacing existing outside lights with 2 motion sensor light fittings as well as putting in dummie dimmer switch module.
5)Tiding up supply cable to boiler.
Includes burying cable in walls changing switch to new fcu
6) investigating what is causing low voltage downlights to blow and slightly burn cables at termination.
Sorry if this may seem like a pestish request but would appreciate feedback
Many thanks guys
Very good questions people. To be honest its fairly easy stuff not too demanding i have been there to see what the job entails i could probably knock it out in a day (obviously anything can happen), Would i be best going for a day rate or for per job for example? Im giving the customer the option to source materials but have offered my assistance in that task. so really just looking for labour costs.
Thanks again!
Thanks again!
Going by what you have said I would charge:-
1.5 x my daily rate + materials with 20% on top.
To put a ough price on them, I know it's a bit of how longs a bit of strong, but taking them literally and as basic as they sound, on the basis on no complications and the like, I'd probably say something like below.
Theres a lot of other ifs and buts Nd variables, but these ate rough prices, say someone said give me a rough price over the phone without seeing it.
1)Under kitchen cupboard LED lights power is already in 2 areas under the cupboard and are already wired to switch. So fairly easy.
Price ÂŁ50 if not supplying lights
Price: ÂŁ80
Price ÂŁ175
Price ÂŁ60
Price ÂŁ40
Price ÂŁ35
I'm not very good at pricing things, generally I underprice, I don't loose out but think, damn should have been another ÂŁ100. That garge I did last, it was a blooming good job, everything in conduit, 3 fluorescents, 5 double sockets, 3 light switches inc 2 way, 2 spurs. Charged him ÂŁ255 inc parts, lol, bit too cheap, he probably wouldn't have wanted it if I said ÂŁ350, so at least I made something rather than nothing.
Uksparks your a good guy thank you very much for your input. I understand there can be many variables which i have taken into account ive seen my routes and know exactly how i will carry out the work and it is as straight forward as it sounds. I came to the ÂŁ300ish mark myself but didnt want to overcharge and under price myself
Many thanks
Lol I dont know much but i think he got a good deal :)
Reply to How much would you charge? in the UK Electrical Forum area at ElectriciansForums.net
ok cheers for the help lads
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
