how often do you change the test leads | on ElectriciansForums
Discuss how often do you change the test leads in the UK Electrical Forum area at ElectriciansForums.net
buzzlightyear
Nearly Esteemed
star command
having been testing a lot of gear recently and using my megger 1720 never lost a bleep and recently why I was testing at the mains and was getting PEFC ok but not PSCC so my thoughts where faulty tester and send for repair ,but having received a new set of test leads separates as a back up and just left them in the office for a rainy day ,so now used the new test leads hay presto now showing PSCC.
On my multimeter I get through a set of decent quality test leads in about 18 months. The black lead usually fails O/C first, at the entry point into the probe, which puzzled me for a while. I started watching how I handle them and realised that sometimes when I run out of hands, I park the black probe in place and press or lean against the end, which stresses the cable in a way that I don't usually inflict on the red.
MFT leads fail but not as often, we tend to use a wide variety of different configurations of leads so the wear and tear is spread out amongst them.
Reply to how often do you change the test leads in the UK Electrical Forum area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
