How often does test gear need replacing? | on ElectriciansForums
Discuss How often does test gear need replacing? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
County Durham
Is there any legislation regarding what test gear can be used for testing. Do the pros have to replace their test kit every now and then or can they use old kit provided its calibrated?
Safe.
Accurate.
Easy to use.
Features.
Calibrated.
In that order.
Age doesnt come into it - unless it impacts on one of the above. It ranks just above colour but behind price. Meters are tools. Its knowing how to use em that counts
Totally agree, why replace perfectly good servicable equipment. 16th edition & 17th edition tester: is there any real difference?
An insulation tester will always test Insulation resistance, bells & whistles only complicate matters.
Reply to How often does test gear need replacing? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
"When stoned..." Brilliant!
Given the apparent lack of earth, combined with no short circuit or over current protection, I'd contend that luck has been the sole factor...
nicebutdim
N
