How tight is tight. | on ElectriciansForums
Discuss How tight is tight. in the Talk Electrician area at ElectriciansForums.net
Kyran
Guildford
Ok so we all know we should do good connections, tight so they don’t creep out of create loss connections.
I know that there is a specified newton tightness but looking in the BGB I can’t see the value and i looking in the wrong place.
reg 526.1 “every connection between conductor or between a conductor and other equipment shall provide durable electrical continuity and adequate mechanical strength and protection.”
Thats all great but how tight should it be?
Can anyone point me at the right reg/value.
All connections should be tightened to the torque stated in the manufactures instructions, there isn't a one value suits all for what a connection should be tightened to.
So it is, just looked in the the box of a waterproof CU i have in the cupboard and sure enough in the first flap "installation" its as terminal bar 1-1.5 Nm and RCD/MCB 2-2.5Nm
Should have look there first
Thanks. Its just one of those regs that just refers to to the manufactures. Ops thanks peps.
well they weren't going to exactly list every make and model of consumer unit along with the required torque setting in the BGB/BYB were they lol
The only time I used a torque screwdriver I was surprised how tight the MI stated value was. It was WAY more tight than the maximum setting on the impact driver I usually use.
Reply to How tight is tight. in the Talk Electrician area at ElectriciansForums.net
Don't worry about the 4A fuse, it's a Keston boiler, it'll be dead by the time you've found one and it's been delivered.
davesparks
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
