How to bond gas! | on ElectriciansForums
Discuss How to bond gas! in the UK Electrical Forum area at ElectriciansForums.net
N
Noob2013
Saves running a cable from the consumer I suppose!
[ElectriciansForums.net] How to bond gas!
Why so surprised guys !!
This kind of stuff is in a lot of homes, and the owners just continue to merrily use it oblivious to the potential dangers, and will tell you its been like it for years, with no problems.
Sad but true, seen it many times, and so will you.
Terrible just terrible, fancy not sleeving the cpc just lazy if you ask me. What were you're other concerns :biggrin5:
"Well it works"
I give up with some people.
Reply to How to bond gas! in the UK Electrical Forum area at ElectriciansForums.net
Although the gas pipe may no longer require the bonding, it should really be terminated correctly or completely disconnected at the other end...
Bonding cables don't need to be insulated, other than for a short section at the end to identify them, and as long as they're 4mm2 or greater are...
