When calcualting the minimum csa for a cpc using the adiabatic equation, how can you work out the csa of the armour of an SWA cable in relation to the amount of fault current it can carry?
You need to know the csa of the steel and convert to copper equivalent csa and use that value in the adiabatic equation.
I think there are links to tables in various threads here
but this is one example.View attachment Conductors size v CPC pvc_xlpe.pdf
Reply to How to calaculate the csa of the armour of a SWA cable in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
