J
joehat
Needing to suspend 40 meters of wire Rope for 1x camera lead, looked at 4-6-8 mm and theirs slot of price difference, is their any way to calc what size is needed or recommended please?
Thank you
Sent from my iPhone using Tapatalk
if you mean shotgun (coax and 12V power) you can hold that up with a washing line.
Will do thanks, I know I've seen a 155kg Max Mark on 4mm, on a 5meter reel, will this be fine on a 40m run or will it stretch and over time?
Just remember over 40m there will be a fair bit of droop on the steel rope. It won't necessarily stretch but you'll have to be quite high to begin with to meet the minimum height reg.
What's the minimum? It's 12v so nothing dangerous and going from 2 story roof hight to roof height on another building all on one property
The OSG has a table in appendix D for minimum height of overhead cables.
A 1mm 7x7 galvanised wire rope will have a load limit of about 70kg and will weigh about 250g over 40m, but you would have to take into account the strain of the tensioning as well.
In truth,the calculation methods for loading a steel rope,are very complicated. For an application,such as yours,experience would allow easy selection,with a factor of safety included.
The SWL on a cable,would,in lifting,hoisting and winching,be at least 5 times less than its' possible breaking strain. Some applications requiring a higher factor of safety.
A SWL in extension,with formed anchors,would not be converted easily,to the load on a wire under tension,with the load perpendicular,along its' length.
You can test this,easily,with a piece of polyprop (blue) duct drawstring,where even a fat dude,can suspend confidently off a single piece,but tie it between two trees,and bounce in the middle...it will break.
This is due to the "advantage" principle,a load at ninety degrees,at the mid-point,applies.
Loads of this nature,on a suspension wire,would include snow,ice,tree matter,roosting birds etc,and give cause to ensure fixings up to the job.
I remember seeing the effect of this,where a local council had fitted some real nice SS wire and gripple fasteners,between two lamp posts,and loaded it up with Christmas illuminations,to the point of bending one steel post,permanently.
How to calc size of wire rope
joehat,
PEG,
