How to choose a ballast | on ElectriciansForums
Discuss How to choose a ballast in the Lighting Forum area at ElectriciansForums.net
Shadyabs
Israel
Hello all,
I am having a bit of trouble with my flurecent lamps it takes them a while to light up, they have magnetic ballast.
Willing to convert for electronic ballast, it's 2 lamps of 36 watt T8 that I have. I attached pictures of the ballast it's like I can't find something like them with :0.43A, 0.90ג
I do not know if they are critical.
What does the 0.43A mean? Amperage?
All electric ballast are about 0.15-0.35A.
What should I do?
  • [ElectriciansForums.net] How to choose a ballast
It is strange , how global warming currently seems to be moving
cold Scottish weather further down the county .
( Had to run kitchen Hobs to get a flash of inspiration -other month) ... Does the room have a radiator !
Hello all,
What should I do?
Replace with an LED fitting.
Unless you have a 'look' to maintain it's not worth messing about with ballasts.
There is a lot of risk in changing a ballast so if you’re unsure ask an electrician to do the job for you, don’t try it.O ther wise you can check through led tubes. T8 LED lights can replace fluorescent lights.
You are exaggerating!
Shut down electricity a bit of time that's it
Reply to How to choose a ballast in the Lighting Forum area at ElectriciansForums.net
Don't worry about the 4A fuse, it's a Keston boiler, it'll be dead by the time you've found one and it's been delivered.
davesparks
I'm begining to think like this now, I very rarely work for builders anymore but the couple that I still do work for are the worst payers out of...
    • Agree
