How to choose the right 3 pole isolator | on ElectriciansForums
Guest viewing is limited
Discuss How to choose the right 3 pole isolator in the UK Electrical Forum area at ElectriciansForums.net
R
Richiespark100
Hi guys,
i need abit of help here I have a 3phase, 440v, 50hz, 1.7kw squirrel cage motor. I need to know how I can calculate and choose the right boxed rotary isolator switch. From my calculations I would do P➗V which equals 3.86. Now this is where I come stuck because it's 3phase do I now times the 3.86 by 3 and say that is my full load current? At the moment I'm thinking of getting a 25 amp isolator switch would this be ok? Please help us out.
Ok guys il try reply to a few of your queries. First of all the type of isolator I want is this: http://www.meteorelectrical.com/25-amp-3-pole-polycarbonate-boxed-isolator-switch.html
also yes it is a 1.7 kW motor 3ph motor it's only a small motor serving as a toilet extract fan working with another 1.7 kW motor as duty/standby. I'm looking to see what is the right isolator to choose. Please give us hand guys
Regards
Richie
Do you want an isolator or a isolator and switch combined in one unit? Your op doesn't seem all that clear.
Switch ratings on rotary isolators will be less for the different duty ratings/types of load.
h
Oh dear, have they taken basic motors out of electricians training now then?
Get yourself along to the nice helpful sticky at the top of the industrial section of the forum.
nope its still there, when I did 2330 amd my mate did 2357 it is in the book and describes the different motors etc.
I know there are advantages and disadvantages to each type but I cant remember as I havent touched motors like that in 2 years and need to brush up on them
[ElectriciansForums.net] How to choose the right 3 pole isolator
(book I got from jtl this is the second time I have opened it)
I've got a slightly older book on the subject, I believe it was printed in 1939 and makes reference to the 10th edition regulations as being the latest edition. I can highly recommend it, it's called 'Stubbs electrical encyclopedia'
Reply to How to choose the right 3 pole isolator in the UK Electrical Forum area at ElectriciansForums.net
