View the thread, titled "How to clear hot water air lock?" which is posted in Plumbers Forums on Electricians Forums.
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering and showing signs of an air lock. I attached cold mains to a hot tap and left it running for 15 minutes, while opening up each hot tap. They all started flowing nicely and I had water flowing from the vent pipe into the hot water tank in the loft. Once I disconnected the cold mains feed though, the hot taps all dried up again. What should I try next please? For background, I have a pressurised central heating system and a Telford Copper Cylinders hot water cylinder on the same floor as the upstairs taps.
Continue reading...
Reply to the thread, titled "How to clear hot water air lock?" which is posted in Plumbers Forums on Electricians Forums.
