How to connect a comms cable between a giv energy battery and a Growatt inverter. | on ElectriciansForums
Discuss How to connect a comms cable between a giv energy battery and a Growatt inverter. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Pepe
west sussex
Good Evening,
Can anyone shed some light on how to connect the comms cable between a giv energy battery and a Growatt inverter.I can’t seem to find it anywhere in the manuals.
Pete
Select suitable cable.
Cut to required length.
Prepare ends.
Crimp connectors (probably RJ45).
Connect cable at both ends.
Edit: Sorry if this seems a bit dry - I thought you were another member 🤦‍♂️
Prepare ends.
😂 sounds like you haven’t installed a giv energy battery with a Growatt inverter either.
I assumed like you there would be an rj45 socket on the giv energy battery. 🤷‍♂️
Reply to How to connect a comms cable between a giv energy battery and a Growatt inverter. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Where are you based?
Hi all, I have a couple of questions I'm hoping you can help with. I have put a solar panel on my kids play house which charges a 12v battery. I...
