How to connect an immersion boiler cylinder stat to a back boiler??? | on ElectriciansForums
Discuss How to connect an immersion boiler cylinder stat to a back boiler??? in the Talk Electrician area at ElectriciansForums.net
B
BlueSparks89
Hi, Ive just started out as an electrician and ive got a job to connect a a new immersion cylinder stat to a back boiler behind fire place.
Is this job easy to carry out and are the connection easy to wire up???
Thanks for your help
if it's anything like the back boilers iv'e come across, you'll have to use FP200.
Thanks do you know how many cores i need and i presume 1.5mm would be adaquate. Do you know the connections? Is it a fairly straight forward job?
easy way to check/control water temp on back boiler.flow and return pipes. you could use a stat that clip on to the pipe [return] very crude but easy job /you can get stats that plumb in the the pipe work .both but needs to be added to a control ciruit.cheers jb
Reply to How to connect an immersion boiler cylinder stat to a back boiler??? in the Talk Electrician area at ElectriciansForums.net
This is an RSS feed of thread: Leaking cylinder around immersion heater Content of the thread: Hi. My hot water cylinder has a small leak. It's...
Electrician Boiler Fault Boiler Fault I’m hoping someone can help with this boiler problem. Couple have just moved into a house that has a Grant...
