how to connect | on ElectriciansForums
Discuss how to connect in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
dolphinm70
hi
this is my first post on this forum. I am not an electrician, but need some help connecting a strip light to an electric plug
i have attached the images of the things i need to connect
the specification is
1. Linolite strip light 221mm 30w
and cables to attach to the mains
could anyone please suggest how i can do that
thanks in advance
DO NOT Connect anything unless you are compatant to do so and by asking this Your NOT contact local electrician or put your location and someone may be near you
Hi and welcome ,firstly what you have in picture 2 lead and plug open a bin and throw it in , cable should be double insulated get a piece of three core flex and a plug with a three amp fuse you will need a 17th edition juction box an ashly J501 will do to replace the one in picture 1 as these cables will require a cable clamp ,connect cables as the colours so the match and those to as on the lable of the plug ensure the plug has a 3 amp (red fuse )
if you are in any doubt in your capabiliteies in doing this please call a spark it will take minuits and should cost very little
Reply to how to connect in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Google tells me that a retic controller is for controlling irrigation systems. I would expect these to have an internal switch, probably volt...
Hi Dave Run a heavy wire from the Driver and down the corner of the cabinet, then solder on a smaller "t intersections of wire to the LED strip...
