how to deal with a borrowed neutral | Page 2 | on ElectriciansForums
Discuss how to deal with a borrowed neutral in the UK Electrical Forum area at ElectriciansForums.net
T
TeeJay711
The RCD trips when either the down or up switch for the stairs lighting is pressed.
. I think the circuit is wired from the bottom switch to the top switch, then to the up stairs light....no neutrals in sight, so i suspect the neutral is from the up light circuit. but the live an earth is from the down light circuit...
Borrowed neutral!!!!
What would be the recommended way to put the neutrals right?
Tony
Thank you all for your help!! Telextric has written what I am looking for. Thank you. Tell me is insanity a nice place!
bootiful. all the voices in my head and the fairies in the bed.
Tony
So how did you verify that there is a borrowed neutral ?
If it is as you say you will either need to run a new neutral up to the light or run a new feed down to the first switch (Tels method).
In either case you will have either a spare neutral or live in need of terminal - ruff......
You could, of course, rewire it properly.....
- - - Updated - - -
Tony
Reply to how to deal with a borrowed neutral in the UK Electrical Forum area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
