B
babySparkie
Hi, need some advice on earthing PVC lighting switches. I am doing an assignment (unit 4, 2330) and normally in the past, I connected the earth from the CCU to the first lighting switch, then with a connector block to the second lighting switch (screwed into the wall) then from second switch with an earth running to the ceiling rose.
I asked my tutor and he said, I can use connector blocks through the first, second switch then leading it into the ceiling rose (without screwing the earth into the wall). He said, pvc doesn't need to be earth and the only reason to have earth in pvc lighting switch is for testing.
Can anyone confirm this connector block method please? And give me advice how to go about it. Thanks
