how to find out which part of fluerescent light anit working | on ElectriciansForums
Discuss how to find out which part of fluerescent light anit working in the Australia area at ElectriciansForums.net
M
m25maintenance
im doing lighting maintenance in a school with loads of flu lights, i know the basics, dead starter or tube, how do i know if ballast r capacitor is faulty, tanx:mad:
I am fairly certain that if a PF correction capacitor goes it does not stop the light from working - it just draws more current. If there are lights not working you could just substitute parts from a known working light. I remember asking when we did lighting at college " how do you check a ballast" - never got an answer :rolleyes:
some fittings arent easy to get replacement fittings for If its not starter /tube its the Ballast/choke some electronit ballasts overheat and will reset after turning power off for a while if its wirewound ballast new ones are easily fitted Electric center and ross ussualy keep supplies of normal sizes 18,36,58,70 Btw mind fit correct starter specialy to 18w series starter they wont start with FSU
Reply to how to find out which part of fluerescent light anit working in the Australia area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
