How to find the main fuse rating? | on ElectriciansForums
Discuss How to find the main fuse rating? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Goody
London
I have a bit of hurdle; I couldn’t find the fuse rating on the main fuse box. Should I ring the DNO for this info? You see, I really don’t want to break the seal (law) to look inside. Thanks.
[ElectriciansForums.net] How to find the main fuse rating? [ElectriciansForums.net] How to find the main fuse rating?
Simple answer, no. The EAWR's do not permit you to work live, so as long as you don't cause criminal damage to the seals (which funnily enough never seem to be there???), then no, it's not wrong to pull the fuse.
In my experience,a lot of cut outs don't have seals on them,but you have to be completely sure that it is safe for YOU to pull the bullet,i.e check the condition,how old is it? Better safe than sorry,and NEVER cut the seals on the meter.
Reply to How to find the main fuse rating? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
sounds like one of those jobs to swerve and let it be someone else's problem
I would hazard a guess your electrician may be able to contact your DNO and have the switch swapped to a MFS very quickly..
