G
greeny
Hi,
Help please.
I have to first fix back boxes on to a wall which will be having 15mm battens and 57mm thick insulating boards . Should I use metal backboxes with a suitable wooden backing in order to bring the back box level with the front of the wall,
or will I be able to use plastic dry lining boxes and somehow push the lugs into the insulation material. The lugs will not be able to fit behind the insulation board because of its thickness.
Greeny
Help please.
Greeny
