How to fix an iron that does not heating | on ElectriciansForums
Discuss How to fix an iron that does not heating in the Electrical Appliances Forum area at ElectriciansForums.net
do you have any sort of test meter that shows resistance or continuity?
Reply to How to fix an iron that does not heating in the Electrical Appliances Forum area at ElectriciansForums.net
I personally have two Integral Evofire Recessed (low-glare) on trial at home outside the UK; just realized they were, however, made of steel. The...
As long as the heat input is greater than the heat losses from the container and the resistance is sufficient to limit the current to no more than...
davesparks
