How to fix unregulated water temp in en suite shower?
  • Thread starter Thread starter JackieVivas
  • Start date Start date
Hello all,
This is my first post here and would be greatfull for any advice on the issue I am having currently.
I have an en suite with mixer shower - concealed. This is in an attic conversion so at the top of the house, boiler is combi and directly below the shower on the floor below. Unfortunatly make and modle of said mixer are not stamped on the unit but I have some photos attached.
The rest of the ensuit was not finished till recently so the shower was not used for maybe 2 years after installation. Now the shower has been put into use, we are finding that the water is either red hot, or freezing cold, despite the position of the handle.
I consulted the Shower Doctor who advised what type of thermostatic cartridge I had and I replaced it, but this did not fix the issue. Shower Doctor also advised to check the non return valves also, which I did but found no debris / blockages, though I dont know what they should look like or how they should operate. These were like round white plastic things which are spring loaded.
The en suite sink, 1.5mts away, has a mixer tap which works perfectly so pressure issues I think would not apply. Pressure of water coming out the shower head is good, both when hot and cold. There is a point when turning the temperature handle where you can almost see the water low change as it goes from hot to cold supply also.
As I understand it the shower is only made of 3 components, the thermostatic cartridge, the 2 off non return valves, so if all are replaced, and the issue persists, then I am a bit stuck.
Hope someone has experience or advice.
Cheers
Jackie
Continue reading...
JackieVivas,
