How to install HIVE 2 with worchester 28i junior from Honeywell bdr91 | on ElectriciansForums
Discuss How to install HIVE 2 with worchester 28i junior from Honeywell bdr91 in the Central Heating Systems area at ElectriciansForums.net
belfast
Hi there, I'm trying to install my new HIVE 2 but having some trouble with the wiring and hoping someone can help me?
Here is my current set up :
I have a honeywell bdr91 wireless receiver and a separate honeywell thermostat both situated next to the boiler at the side of the house as shown below -
[ElectriciansForums.net] How to install HIVE 2 with worchester 28i junior from Honeywell bdr91
As you can see I have Negative then Live then a jump wire going from the second L to A, then I have another wire with brown tape on it going into B
The thermostat im not sure if I should be leaving it alone or it will need removed also.. but I have Earth - Neutral - and 2 brown wires I have labelled 2 and 3.
The above set up is fully working but different to some videos I have watched on youtube,
Now I would like to figure out what wires I need to put into the hive 2 system -
ANY HELP WOULD BE GREATLY APPRECIATED AS I CANT FIGURE IT OUT!
try British gas ,they can help !
Go careful... British Gas installed a car charger for somebody I did some work for , put it on an outside wall, fed from PME and didnt install a rod as its not feasible or reasonable and wont affect how it works... In laymans terms - we cant be bothered to put one in and run a cable to it. The person has since filed a small claim at county court against them as the guy claims it is not fit for purpose and the dno have no record of it being installed either. He has also got the dno on side as the contractors pulled the fuse so is making a right big deal of the lack of safe isolation... seems the sub contractors being hired by british gas are putting them chargers up in quick time and off to the next job. from what i gather centrica are keen to put things right and avoid court hearings!
Might be worth noting I have a worchester 28i junior boiler if it helps anyone help me, i'm not a fully qualified electrician but I work with pcbs etc and pretty handy with wires so was hoping someone could just point me where to put them..
It's bread and butter work for a jobbing electrician. Prob no more than ÂŁ40-ÂŁ50 and you have the peace of mind it's been done correctly. They will check if the earths are connected correctly etc.
Hi
This is relativly easy stuff, and if your as good with wires as you stated it shouldn't take you more than an hour to install and test.
I would also remove the wireless receiver wiring and replace with 5c flex. If that is a frost stat i would ensure that is connected to the correct terminals in the boiler.
Reply to How to install HIVE 2 with worchester 28i junior from Honeywell bdr91 in the Central Heating Systems area at ElectriciansForums.net
That's just a standard timer switch. The 2 red wires to the timer are the switch contacts, the 2 blue wires are power to the clock. The 'orange'...
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
