FraserJim
I need to re-route some circuits from one surface mount panel to another. There is a 4” gap between the two. I want to use 1” PVC or EMT. Because of the limited space, I am looking for suggestions for a legal, secure method.
Discuss How to install rigid conduit between two surface mounted panels? in the The Welcome Forum area at ElectriciansForums.net
Use couplings on both ends of your pipe which will slide between the panels, then use bushings to secureI need to re-route some circuits from one surface mount panel to another. There is a 4” gap between the two. I want to use 1” PVC or EMT. Because of the limited space, I am looking for suggestions for a legal, secure method.
Reply to How to install rigid conduit between two surface mounted panels? in the The Welcome Forum area at ElectriciansForums.net
