Having some 1400W 230V heaters to test and repair that have a power trip problem. I've unplugged all the connections and open them up one by one to identify the part that is causing the trips.
Everytime it trips, it trips the whole place through the main circuit breaker. How can I do it safely and not trip the entire office? I've used some of those masterplug rcd adaptors and they don't work, still tripping the entire place but I've plugged them to an extension though if that matters.
Other than that, I usually I test the heating element first because they are usually the cause. What should be the other tests that should be done?
- TL;DR
- How to test appliances that trip but don't trip the entire location?
