How to lan work two computer | on ElectriciansForums
Discuss How to lan work two computer in the Computer and Networking Forum area at ElectriciansForums.net
I'll assume there is one computer already working, and you want to add another. So :
1) Does the first computer plug into a router via a LAN cable ?
2) Does the router have more than one LAN port on the back ?
If both are yes, then just plug the second computer into any of the spare LAN ports on the router and it should just work.
If 2 is no, then you'd need a switch to expand the single LAN port to "multiple". Connect the single LAN port on router to the switch, then each of the computers to other ports on the switch - then it should all just work.
If the answer to 1 is no, then more information needed.
Reply to How to lan work two computer in the Computer and Networking Forum area at ElectriciansForums.net
While there are some valid points, no-one has mentioned the most important. YOU NEED THE RIGHT PLUGS. "RJ45"* plugs come in different types...
Many years and forums ago it was Astroboy until that name was always taken so I went for Astrobpy that way I knew no one else would have that...
