atwosheds
Years ago, I cut off the front end of my 1970 Pontiac Catalina before I drove it to the junkyard. I created a bracket and mounted it to my garage wall and successfully hooked up the four headlights and side marker lamps to a power supply that converted my 110 household AC current to the 12 volt DC that the bulbs required. It was a total success. (see picture below) However, this year I moved into a new home and I am converting my masterpiece into yard art. I have created a small outdoor bar (see picture below) with a roof which is far away from any household circuit and I would now like to power the auto car lights from a battery with the intention of adding a trickle solar panel charge to it making it completely off-the-grid. I purchased an ExpertPower SLA battery (12v 7Ah/20 HR) and hooked it into the car wiring. All of the lights lit up just fine but I quickly noticed one problem. When I touched some of the wiring it was quite hot. I quickly disconnected the circuit. After a little research, I realized my wiring was way undersized. The skinny 18 gauge wiring was just fine with the converter. It seems I should replace all of the wiring with 10 gauge and add fuses to each device. The four lamps are 60 watt each and I guess the two side lamps are 3-5 watts each. My question is will the thicker wiring by itself solve my overheating problem? Do I need a smaller battery, and if so, what specification? Or do I need an additional device to dial down the power to the lamps? I do not want to convert the lamps to LED. I am desiring to keep the lamps authentic. Thanks for any help.
Pontiac Front End formerly mounted on garage wall using a 12v power converter:
Outside project (work in progress):
