How to quick connect pv panels to controller | on ElectriciansForums
Discuss How to quick connect pv panels to controller in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
H
Hound
Hi all.I need some advice from the pros.
I want to install two[2x 100W] semi-flexible monocrystalline pv-panels stitched into the bimini of my boat,using waterproof[IP68?] quick connect/disconnect couplings and do not want to have to buy expensive tools for a one of job.
The panels come with"bare end" dangling black and red wires and I do not want to hardwire them together in parallel.I would like to be able to connect/ dis-connect them individually.
It would be nice to be able to plug them both into a fitting mounted above the deck for easy removal and to avoid having to run two sets of cabling all the way back to the controller which is mounted below deck[say,8-10m of cabling away]-although this would not be the end of the world.
Please specify what I would need.
Thanks,
Tony
connectors sunclix IP68 tooless , 10amp charge controller for the modules also IP68
IP68 marine semi-submersible/waterproof , have both in stock if required
Reply to How to quick connect pv panels to controller in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
