Discuss How to reset boiler Horstmann 7 Economy? in the UK Electrical Forum area at ElectriciansForums.net
Electronic or manual version?
[automerge]1600621917[/automerge]
If it’s the electronic hold down the Boost, Plus Minus and Select buttons together to reset the unit. You will have to reset the programmes and times most likely.
Ahh ok. I’m not 100% sure on them, if I remember rightly there is a a lot under the cover at the top of the clock to set them. Sure one of the older boys will have a better answer for you though.it is manual version
Agreed. I’ve had to attend to several of these. A replacement was the case, every time.If the time clock dial does not turn to keep time, it's time for a new unit.
Time clock is workingIf the time clock dial does not turn to keep time, it's time for a new unit.
Reply to How to reset boiler Horstmann 7 Economy? in the UK Electrical Forum area at ElectriciansForums.net
