how to reverse a sing phase cap run cap start motor? | on ElectriciansForums
Discuss how to reverse a sing phase cap run cap start motor? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
RJP1
Lincolnshire
Hi I had a job last week I struggled with, I'm not clued up on motors like I should be but the problem I had was making a single phase cap start cap run motor reversible. All I was doing was replacing the motor but I want to understand exactly what needs to be done at the motor to allow it to be reversed?
Any help would be great full.
Reply to how to reverse a sing phase cap run cap start motor? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
I got this all wired in and working thanks to the help from James, absolutely top man. Do have a small issue with current imbalance atm, L3...
