How to safely cover unneeded live wires? | on ElectriciansForums
Discuss How to safely cover unneeded live wires? in the UK Electrical Forum area at ElectriciansForums.net
cable_guy
hi all,
I just took off a light from my lounge wall hoping to replace it, but i'm going from a double light to a single, and there are 2 feeds for each previous light.
How should I best cover the old wires I no longer need? I looked at plastic caps but there isn't enough depth in the wall cavity to put these around the wires.
thanks
trace the cables back to under the upstairs floor. cut and join with wagos in an enclosure. don't leave live cables in a wall, going to nothing. alternatively, where the light was, fit a knock-out box and blank plate.
pictures - hope they help!??? thanks v much for replies thus far.
http://i.Upload the image directly to the thread.com/295Cs9b.jpg
http://i.Upload the image directly to the thread.com/hK5fULb.jpg
jeez. what a mess. how many T/E's are there, 2 or 3? i'd be inclined to cut out for a single 25mm box. tidy it all up, connect with wagos ( or line products connectors, then fit a blank faceplate. that also give you the option of fitting a light in the future if required.
unsure what you mean about T/E Tel, but there are 6 wires in total, 3 for each original light. TBH in my capacity as knowing nothing about electricity, I thought it was rather tidy! 2 feeds for 2 lights all tightly joined in a tiny plastic junction box thing! :)
Reply to How to safely cover unneeded live wires? in the UK Electrical Forum area at ElectriciansForums.net
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
