K
Kyle Chadwick
hi lads recently passed my 2394 and 2395 and am currently working cards in for a firm just wondered how i go about joining an approved scheme so i can do test and inspections out side of work and advice please
Discuss how to self certify in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
:speechless: .hi lads recently passed my 2394 and 2395 and am currently working cards in for a firm just wondered how i go about joining an approved scheme so i can do test and inspections out side of work and advice please
Inspection & Testing isn't 'Notifiable' work, so you don't need to inform the Local Council and you certainly don't need to join a scheme!
The only requirement is that you are 'Competent'.
If it is an EICR then you are not even saying it is safe, you are saying it seems safe and you are only saying that about the bits you have agreed to inspect with the customer.so all you do is create a copy for the customer (who doesn't even know if it meets the requirements?) E.g if the electrician fails to spot a problem (dodgy spark) and the customer "thinks" they are ok with the results but they are not.
.....you are not even saying it is safe, you are saying it seems safe .........
Reply to how to self certify in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
