A
Alan Mcgroarty
hi newbie post here but seems best place to get an answer.
i have a radial circuit of 5 9w led downlighters, with 2 on lower hall and 3 on upper hall, with a 4 way switch setup (1 switch downstairs the other 3 upstairs).
This arrangement is bizarre and i'd like to split the circuit in two so i can switch us/ds independently.
The drop for first switch is into a switch downstairs, and the other 3 are upstairs with a bog standard multi way wiring.
Is there ANY easy way to split the circuit without rewiring the whole shebang.
My current assumption is that I need to run effectively a new radial circuit from the JB that provides the L/N for the current circuit, up to the first fixture I want to switch independently.
I then need to put a new drop in to the first upstairs switch from that new radial. Fitting a new 2 g switch here would let me still control existing circuit, and the new one.
I can then hijack the remaining upstairs switches and use their existing wiring to now switch only the upstairs.
The only other option i can see is to use RAKO wireless but they are not really right for this sort of location, and doing the whole lot (4sw and 2controllers) is ÂŁÂŁÂŁ.
Any other elegant solutions that I missed - starting to feel resigned to some wall ripping, and paying of sparkie to do this.
any help appreciated. thanks.
