Discuss how to take supply from split rcd board without rcd protection in the UK Electrical Forum area at ElectriciansForums.net
it is swa but i want to eliminate any chance of rcd tripping the house consumer unitfine as long as the cable feeding the shed does not , in itself, require RCD protection. e.g. SWA.
please do mateMaybe a spark needs to come in advise you.
all depends on if you have a non-RCD weayin the house DB. if so, it's simple.
Cheers wilkoHi - my preferred method now is to implement the new distribution circuit to the shed with an RCBO as this will provide protection for the whole circuit and shed. You might want to consider a DP iso to dis the outbuilding in the case of a N-E fault on the cable. I see you’re a Trainee, so perhaps ask a Moderator for access to that section if you’ve not already.
Reply to how to take supply from split rcd board without rcd protection in the UK Electrical Forum area at ElectriciansForums.net
