how to test the motor circuit in 2391? | on ElectriciansForums
Discuss how to test the motor circuit in 2391? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi, i failed the 2391 practical exam, i did the one phase part quite well,but very very slow when i did the 3 phase,
when i do the 3 phase, there is a motor, shall i open it and the isolator to test the continuity? test between CU and isolator, isolator and motor to get the other continuity in 2 steps?
cheers, also any tips on the 3 phase will be strongly appreciated
To do the 3 phase motor circuit continuity do the (long lead method) R2 not the R1+R2 test. Test from the 3 phase board to the socket. But ensure you open the isolate to check there is a continued earth there.
Insulation resistance test.
10 tests from 3 phase board and 6 tests from socket.
Upvote 0
Reply to how to test the motor circuit in 2391? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
I believe that it is incorporated into the 5 days. But will double check. Thanks.
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
Electrical Courses
