We are currently having a new office fitted out. It will include a 2P+E 32A socket (Gewiss Interlock Socket 32A 230V 2P+E - https://www.eleconline.co.uk/zdriverel/form/catsel/INDUSTRIAL-PLUG/SKTS/product/M1643) for our UPS. I want to run my own tests in advance of moving in, to be completely sure that the socket and power to it are all fine. What is a good way to do this? I've seen this Socket & See SOK40/16HD 230V Industrial Socket Tester - Socket Testers - Electrical - http://www.test4less.co.uk/socket-amp-see-sok40-16hd-230v-industrial-socket-tester.html but I don't know how thoroughly it tests the power supply. Is there anything better?
Which specific tests do you want to perform?
Plug in socket testers don’t thoroughly test the supply, they provide a quick check of polarity and a helpful noise to assist in finding the correct mcb when switching the circuit off.
The electrician or electrical contractor who has carried out the installation work will inspect and test the installation then issue you with an electrical installation certificate. As part of this certificate there will be a schedule of test results which details the results of the tests carried out.
Bsolutely agree a full EIC test is required
London
How to thoroughly test a new 2P+E 32A socket
Electrical Tools and Products
matthewk,
Pete999,
