How to use a two pole voltage tester? | on ElectriciansForums
Discuss How to use a two pole voltage tester? in the DIY Electrical Advice area at ElectriciansForums.net
smash_
London
Hello guys,
just looking for a bit of advice, I’d like to be able to use a voltage tester at home when required.
Are there any good videos or tutorials?
thank you
Chris is sound chap.
Had him as a tutor for my inspection, testing and initial verification courses.
Reply to How to use a two pole voltage tester? in the DIY Electrical Advice area at ElectriciansForums.net
I think it was too early yes I meant 3 not 2, but great I'll give that a whirl and thanks.
C'mon admit it, I won't judge you. This is where the ol' trusty neon screwdriver makes a cameo appearance. You can prove isolation and tighten the...
