How to use an extractor fan with a dimmer switch? | on ElectriciansForums
Discuss How to use an extractor fan with a dimmer switch? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Evening all....
My son is 14, he seems to be taking ultra long baths and showers and the bath/shower room is drenched afterwards.
I have just bought a pretty good inline fan and was planning on fitting it on its own switch as the existing lights are on a dimmer. I would love the fan to come on with the lights so that it is guaranteed it comes on when he is bathing.
Is there any way of doing this on a dimmer? The dimmer will be staying as it's too bright at night when on full.
I thought I could install a standard plate switch which switches power to both the fan and the dimmer switch. in other words the dimmer switch doesn't get power unless the fan is on. However, this is too cumbersome. Is there any way the fan can work with a dimmer switch?
A few more questions..
What actually happens to a fan if you install it on a dimmer switch? I'm guessing it would work fine if the dimmer is on full, but problems occur if the dimmer is lowered? Would this be dangerous or would the fan just cease to work as it doesn't have the required voltage?
Evening all....
Could you put a motion sensor in . Then it would work any time you enter the bathroom
You can obtain single plate switches with a rotary dimmer and a rocker switch side by side, with independent connections, so that is a viable method - is it cumbersome because of having two 'knobs'? Or is it because of having to add/re-route cables?
Edit - assuming it's a timed overrun fan, the dimmed connection will act as the trigger for the fan to come on, but surely the motor will be powered from permanent live, so will either work properly, or not come on at all? I suspect the dimmed feed to the fan might trigger it more or less at any setting?
Yes, it can be done, but the dimmer module will need modification.
I initially tried to do this using the dimmed switch live from the dimmer to the SL of the fan. It sort of worked, but the fan took ages to be triggered, about a minute or more IIRC. Back to the drawing board.
The modification to the was easy enough to do, and worked perfectly. John Ward has a video on how to do it on old leading edge module, but the way I did it on a V-pro module was less faff. I'll PM you details.
Haven't fitted a dimmer switch since the rise of cfls and now LEDs, so a bit out of touch with what's on the market, but if your dimmer has a physical mechanical on/off switch incorporated into it's design, and is dismantlable, you should be able to solder a fly lead onto the switch output, before it feeds the dimmer.
Wouldn't be acceptable for a customer, but if it's for your own house...
I'd be very interested in this 'hack' too...
As mentioned by someone else above - just fit a humidistat fan and let the embedded controller do the hassle for you! Probably end up cheaper, too.
Reply to How to use an extractor fan with a dimmer switch? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
