Hello, well if I was doing an outside conduit, the first thing I would do is all of my bending, sizing and forming, get the galvanised saddles fixed to the wall using stainless steel or Brass screws, then I would galvi paint all of the bends, as the original galvi crumbles off when you bend the tube, it fractures and flakes off, after that, I would get all my joining pieces together along with any bushes and lock rings.....
when you thread your tubing, use WD 40 instead of tallow, it cleans the threads as well as lubricating them, give them a scoosh every time you unwind the tap&die threading tool and give it a gentle tap as well, this will remove all the metal shavings, and the WD40 helps make manipulation and tightening easier, once you have your conduit ready, you should look up something on ebay called Liquid Levers, its quite expensive for the little sachets you get but its amazing stuff and always good to have in the toolbox, its American made stuff for waterproofing Electrical seals, a company up here in Scotland sells it on Ebay, you put a small amount of this on the thread before assembling the end boxes/through boxes onto the conduit etc and it forms an airtight waterproof seal, after you have assembled the through boxes and end boxes, if you have drilled through the back of any of them to fasten them securely onto the wall, put a little Galvi paint over the screw head inside the backbox/end box.....once you have got all of the tubing together and all tightened up, and wired it with your 3 singles, fit round rubber gaskets on with the Galvi metal lids, they only cost pennies and if you dont then the edges will eventually corrode inwards on the lids as they have a different electron displacement corrosion index than the tubing, due to being lighter and thinner metal (sacrificial displacement) and will end up acting like the sacrificial Anode on a boat Engine, if they corrode inwards, water starts seeping in from the edges.....this is only a problem in direct rain and rubber gaskets are not needed in areas under shelter with only air moisture content to deal with...
Once you have finished the tubing,give it all a quick coat of Galvi paint just to make sure that it lasts for a long time, and you can paint over this after about 2 hours with either Hammerite exterior paint (comes in tins as small as 250ml I think) or any colour of exterior gloss that suits the wall where its going, this will leave it looking the bees knees and well impress your customers...
Remember to take the round file to the ends of the conduit before you screw the end boxes on to get rid of any jagged bits on the inside edge, that will save you from stripping the insulation off the singles, if there are awkward turns in it and you dont want to pull too hard when wiring, I find that a bit of Fairy liquid does the trick and does not do any damage to the wires, dont use tallow for this as I have seen it done several times, it makes a mess everywhere and might even perish insulation after a short time...
