How to wire a pipe stat | on ElectriciansForums
Discuss How to wire a pipe stat in the Central Heating Systems area at ElectriciansForums.net
I
ianb26
Guys, this will be simple for you but a head ache for simpletons like me.
I've installed a wood burning boiler stove and now want to oil boiler to work as a backup. The solution is to fit a pipe stat to the flow side of the stove and leave the heating on constant and turn the boiler temp down or off when we don't want heat.
However, we don,t want the pump to run 24/7. So I want to have the pipe stat switch the pumps on when the fire is lit or the boiler temp is turned on.
Is this possible and if so what wire goes to where?
Is the tank vented or unvented? Is there a neutralizer fitted? Might need more than one stat NO/NC fitting, hard to say without knowing the system in greater detail.
Reply to How to wire a pipe stat in the Central Heating Systems area at ElectriciansForums.net
Are there long pipe runs ? Although not a legal requirement, the HSE recommends hot water should be delivered at 50ºC within 1 minute to help...
The 4 pumps are :- 1. boiler to cylinder 2. C/H and UFH circulating pump 3. UFH dedicated pump after manifold 4. DHW circulating pump. (this just...
