W
whazza22
Hi there,
Just after some advice on how to wire the attached drawing (apologies for kids drawing haha)
http://s193.photobucket.com/albums/z53/whazza22/?action=view¤t=EmLight2.jpg
Im trying to wire a light fitting with 2 x 70w T8 tubes. I have a ballast and a P4 Fastel Inveter.
Im ok when wiring a ballast and emergency light inverter when they both have 8 connections but for some reason this ballast only has 6. It shows one end of each lamp link together (hence 6 terminals not 8). This is catching me out as I have a terminal left over.
The ballast shows 3 connections to one lamp, 3 to the other lamp and a link between 2 ends. The inverter shows 4 connections to em. light and 4 to the ballast.
Could some explain or re-use my drawing to show how to wire please.
Thank you
Thank you
