ricedarren
Discuss How to wire sauna heater in the UK Electrical Forum area at ElectriciansForums.net
I've a multi meterop are you going to wire it your self and have you got the correct gear for testing .
There's only 6 on the diagram. On the sauna there are 7 wires. I know third is single phase, bit sauna looks like it's the first diagram, which is three phase which makes me wonder has manufacturer made a mistake and wired it for three phase.Bottom section shows how to wire for single phase.
The are two switches, timer and heat/on/off. Timer on left, heat/on/off on rightHi there, not sure to wire this in parallel or series.
Also, this seems to pre wired for three phase not for the home, but suppliers say it is for home use.
Any help appreciated. Thanks
are you wiring the full system up your self .what wiring are you puting in.I've a multi meter
I've a multi meter
Hi there, no, the the electrician left the wire in the sauna for me. So all I've to do is connect with sauna heater to supply via the correct heat proof wire.are you wiring the full system up your self .what wiring are you puting in.
A multimeter is not suitable for carrying out the tests required by the wiring regulations, nor is it suitable for carrying out safe isolation. You can of course ignore our advice about this and continue anyway, after all it's is only your life which you are placing at risk.
All three wiring diagrams apply to your sauna, they show the three different possible supply configurations.
The first connection diagram explains the purpose of the 7th terminal, repeating this two more times would make the diagram unnecessarily confusing so it is left off.
Hi thanks, I'll not ignore advice. But I'll take everyone's kind advice under consideration. Thanks again re the diagram, I hadn't thought that they'd do that! Just not sure if I can simply use a four pin bus bar or not though.A multimeter is not suitable for carrying out the tests required by the wiring regulations, nor is it suitable for carrying out safe isolation. You can of course ignore our advice about this and continue anyway, after all it's is only your life which you are placing at risk.
[automerge]1572128822[/automerge]
It is wired for 3 phase and single phase.Also, this seems to pre wired for three phase not for the home, but suppliers say it is for home use.
They are the same size as the internal wires. Should I try for larger?or wire in parallel? The heater is working fine though.What is the load of the sauna?
Are those links you have put in capable of carrying that load?
It's 4.5kw. the shop, not the manufacturer, said just now to use two U Links.They are the same size as the internal wires. Should I try for larger?or wire in parallel? The heater is working fine though.
why? the links look fine. The links come from the manufacturer, surely you aren't questioning them?I would make the cable links the same size as the incoming cable size.
Reply to How to wire sauna heater in the UK Electrical Forum area at ElectriciansForums.net
