How to wire sauna heater | Page 2 | on ElectriciansForums
Discuss How to wire sauna heater in the UK Electrical Forum area at ElectriciansForums.net
London
Hi there, not sure to wire this in parallel or series.
Also, this seems to pre wired for three phase not for the home, but suppliers say it is for home use.
Any help appreciated. Thanks
  • [ElectriciansForums.net] How to wire sauna heater
why? the links look fine. The links come from the manufacturer, surely you aren't questioning them?
The incoming cable should be sized for the power consumption of the item. The links will be taking the same current, therefore I personally would use links the same size as the incoming cable.
The choice is yours to make mate.
Sure, the supply cable should be sized to carry recommended current. The right size links are already chosen by the manufacturer, so the choice has been made for us. I guess the trick is in choosing the cable size, not the links.
The homemade live links won't be taking the same current as the supply cable, the firs link will take 2/3 and the second link will take 1/3.
The neutral link appears to be factory fit so should be sized appropriately for the expected current.
Reply to How to wire sauna heater in the UK Electrical Forum area at ElectriciansForums.net
Hello All, This is Vaithees from India. We are using an IR heater for a vacuum & non-vacuum chamber and got a heater from Chinese company and its...
Interesting item you have there. This blog might be worth a read https://sllipblog.wordpress.com/2014/04/29/its-now-00-28am-and-i-need-my-bed/...
