How to wire swa to flex of different sizes | on ElectriciansForums
Discuss How to wire swa to flex of different sizes in the Australia area at ElectriciansForums.net
I'm getting dejavu here...
http://www.electriciansforums.net/e...n-swa-flex-via-terminal-block.html#post346868
Option 1
Do as already said but use a 6 amp breaker at the origin of the SWA and prominatly mark as not to be changed in anyway, or preferably...
Option 2
where you make the joint to lower cas cable you'll have to fuse down somehow. Maybe a metal box, gland the SWA into it, a FCU on the front lid, then a gland out the other side for your flex.
Reply to How to wire swa to flex of different sizes in the Australia area at ElectriciansForums.net
Sounds more positive.
Can you do a sketch of the wires and their connections but @littlespark is probably correct.
