How would I wire two lights from a two way switch in singles? | on ElectriciansForums
Discuss How would I wire two lights from a two way switch in singles? in the Australia area at ElectriciansForums.net
M
Mr Curnow
Would there be two lines from - Consumer unit> Two way switch> Lights
- Consumer unit> Lights?
Or Just one line from - Consumer unit> Two way switch> Lights?
The earth would go from the - Consumer unit> Two way switch> Lights
The neutral would go from the - Consumer unit> Lights
.take 1 feed from the CU to the 1st light, add switch wire as normal in rose, other end of sw. wire to L1/L2 on nearest sw. 3 core from sw1 to sw2. loop 2nd light from 1st rose s/l and n. joint cpc's at each point.
Here you go mate, hope this helps.
[ElectriciansForums.net] How would I wire two lights from a two way switch in singles?
Consumer unit to common on first switch, two cores between switches connecting L1 to L1 and L2 to L2, then from second switch to first pendant then on to second pendant connecting at the SL point (flex) in both cases. A neutral then need to go from CU to both pendants and earth wires looped round switches and pendants. Hope that makes sense.
Dunc's is the one you want. Standard configuration, It's not usual to take live feeds to lights when wiring singles in conduit,although there is nothing wrong with tel's method,I'd guess they will be looking for Dunc's.
every electrical switch , socket and accessory is in effect a junction box, it,s just that they have another function too
giio, i meant a junction box stuck under the floor somewhere as opposed to jointing in a switch box or fitting, where connections are readily accessible without having to hunt around for a JB.
That is what I thought at first, my teacher told us that way, I think I need a bit more explanation on the wiring between the two lights. I was getting confused reading telectrix's method.
Reply to How would I wire two lights from a two way switch in singles? in the Australia area at ElectriciansForums.net
Thanks again for your help, now solved đź‘Ť
In addition to Brians post above you can get electronic impulse relays, so no thud as they switch in and out.
