- Joined
- Dec 13, 2008
- Messages
- 105
- Reaction score
- 16
Hi all,
We are on the verge of having a detached (by about 30 metres) garage built which will have accommodation upstairs and a small bathroom, I'm trying to work out the best way to heat it, I don't want to start installing separate boilers, pumps etc for a wet system so I was wondering if there is anything suitable in the electrical line, I have seen some flat space heaters but I'm not sure if building control will think they are 'green' enough. I will probably have to have a small header tank above the bathroom for the shower as the mains pressure here is rubbish but I don't think there will be enough capacity for anything else. I'm going to be running a 16mm SWA to the garage so if needs be I can run something that has a reasonable load. Just wondering if anyone knew of anything new and exciting (and not too expensive) that might fit the bill.
Down2earth.
Down2earth.
