How would you put this right? | on ElectriciansForums
Discuss How would you put this right? in the Talk Electrician area at ElectriciansForums.net
T
TPES
A house that has 2.5m T&E from the back of a kitchen socket (ring) outside the wall in a thick water pipe burried 2ft underground, travels about 7 meters to an outside building (brick shed) and comes up from the floor of the building about 1ft, this at the minute is just connected to a 30a JB.
From this there is planning to be 2 sockets and a couple of lights.
Now i know if i was to do this from scratch i would run on its own circuit using SWA and fit a garage unit.
But the owner of the house is determined to keep this as it is, and just wants it making safe and as right as can be.
Now this cable is RCD protected as it comes off the ring main of the house.
How would you isolate the supply feeding the outside building ?
How would you connect this inside the outbuilding to feed a couple of sockets and lights ?
Sid here's a link from the IEE about out building supplies. It is to the 16th Ed but least it will give you some options.
http://---------------/Publish/WireRegs/WiringMatters/Documents/Issue16/2005_16_autumn_wiring_matters_electrical_installations_outdoors.pdf
Warren
Ahh good link,
just what i was thinking double pole isolator!..
wasnt sure tho... but you have just confirmed it
Sid here's a link from the IEE about ouy building supplies. It is to the 16th Ed but least it will give you some options.
Warren
Garage supply taken from a spur off the downstairs ring final circuit
So the switched fuse spur would have a 13a fuse in it, and a 20a double pole isolator in the shed ?
Suelry if there's quite abit of load coming from the shed, couple of lights on, things plugged into sockets isnt there a high risk of popping the 13a fuse?
Is this a really dumb thing to say? ..lol
Yep done a simliar job at my place a good while back, but I did use a FCU off the ring, SWA and a small two way board for the circuits into my shed.
The only thing I would say if you took the route I did is that you need to think about discrimination between the two RCD's form the your main CU and the sub CU.
Sorry Sid we must of typed at the same time. I would check to see what is going to be used in the shed in terms of load?
2 x ip light fittings also 2 double sockets, would be used for garden equipment (lawnmower, strimmer) also power tools could be used from time to time.
if you are supplying a seperate outhouse you need to change the earth system to a tt as you are not allowed to relly on the supply earth
this meaning you would not terminate your earth of your outhouse supply cable at the outhouse side and then supply an earth rod as a means of earth..... this is in the regs
geecam
geecam
Good point
All depends what earthing system the house has , as to whether or not you can export the earth
Reply to How would you put this right? in the Talk Electrician area at ElectriciansForums.net
It might be ok
When he bought the bank, they stripped out all the metalwork, iron bars etc for scrap. He was left with the cashier countertops… which have been...
