Discuss How you work out fuse size in the UK Electrical Forum area at ElectriciansForums.net
he even asked me could i use some of old wiring....
Can I have some of the stranded imperial stuff, this 2.5mm solid core isn't the best.Would you like to buy some old coloured cable?? :cowboy: :wink_smile:
You're right I expect, have seen similar to those as fuse carriers but it may have been in industrial in control panels.Think D80 was thinking that block which the red is going into was a fuse carrier, but it looks like a connector block only.
There is a good chance that you maybe able to get your customer an upgrade on that beast. Get hold of the DNO and tell them that when the system is loaded you can hear crackling, there is a good chance that there maybe a fused neutral in there as well.
As for the no load I should be fine .....................be careful son because if you have a shared neutral on that with another house under a 3 phase system you will get a nasty belt
Reply to How you work out fuse size in the UK Electrical Forum area at ElectriciansForums.net
